trunk build
  • 1
Quaid_Station
I'm looking to get either 1 15 or 2 12's
Put into a trunk and I want to be able to do a hair trick.. I'm not looking for a full out crazy hairtrick but a noticeable one.
My budget is $450
I already have a Alpine MRX-240 amp
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
813
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
Quaid_Station
Quaid_Station
huntington, IN
Quaid_Station
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
