Southwest Region Trunk car class.....????
AZ,CA,NM,NV,UT
so you have a total of 3 batts right? and highest i think ive seen was like a 157. and not like you have to do a 157 to be competitive. it really depends on whos at the show. ive won ss nw with a 146.8 before 2nd was a 145.8 and 3rd was like a 140
No he only has two batteries. He said the stock car battery is also mounted in the trunk of the car, so he only has one extra battery other than stock location.
yeh he said 2 hc2000s so i guess one in the stock location. but like i said who depends on who is in ur class. your gonna have crx's in street classes doing anywhere from like 152-155
hes in cali. i know they got iasca over there. but they dont do trunk classes either. im not sure what class he would be in that either. they keep changing the rules. i know ive done stock 1 with 2 batts, but im not sure if he would be in there stock 1 or not
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
741
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
Bhhong
Bhhong
SD DAYGO CALI
Scuba
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
