trunk cars
jdawg90
alberta
Is having a box in the trunk that takes up pretty much the entire trunk's airspace a bad idea when going a sub up/port back configuration? I can fit 2 15's in my trunk if I do subs up port back, but the boxwould take up the entire trunk (I mean there is not much room left AT ALL).
That's what I was thinking, I could do them sub/port forward and seal off the trunk.
you could do 4 8's and it would SLAM. Depends on how much money you wanna spend too.
That was the original plan. I bought 2 sa-8's and a saz-1500d planning to double up but I'm not sure if I wanna go that route or some other route
I have my setup sub up port back in my car and it still slams
Yeah, but how big is your box?
I'm just weighing my options right now. I could fit a 18 sealed off from the trunk, but that is exactly what basshead did and I'd like to do something original. I'd like to do 15's if that setup wouldn't hurt me over going with smaller subs/more airspace in trunk. Also considering 4 sa-8's or 2 x-10's in a 4th order sealed off.
how much space will you have between the port and the back of the trunk?
If your goal is purely loud it will probably be ok but when the box gets too big for the trunk it tends to hurt the lower notes in my experience. Cabin gain down low will be better using 12's or 8's or 10's.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
814
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
jdawg90
jdawg90
alberta
T3mpest
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
