Trunk position matter for a sealed box?
  • 1
Mechorganic
25
Miami
Ive read a lot that for SPL the ideal positioning in the trunk is for the subs behind passenger, port behind driver. Does it matter for a SQ system and a sealed box? Im only putting 1 10" and trying to figure out which way to face it and which side itll go on, so i can get my box properly designed.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
816
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
Mechorganic
Mechorganic
Miami
Mechorganic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
