Tryin' for a larger/more efficient box... Help
  • 6
If you happen to have the t/s handy, send them to me and I'll run them through winisd to get the correct velocity for port area and best tuning for them, along with power being used. That is if they are true t/s. Of course real world in the vehicle dictates all but don't ever guess on the correct pa/tuning.
Sent from my SM-N920V using Tapatalk
Thanks again for the help, them plans look great... now time to quit vacillating and get busy... I'll be cutting my 45's with a cordless Skillsaw... Wish me LUCK!.. I'll update when done!
Lets update... Done!.. Finally, in and playing! Sounds Great so far... Definitely some increase at 40+ hz and still goes low well... "tuned to 30 hz"... Seems to make more efficient use of what power I have available... Slams well but now seems to have a little more Spl at higher frequencies... Props to CSCstang for all the help... The original box was manufacturers spec and sounded great, and could really play low with an external port extension... "23 hz!"... but now with the 5 ft3 box and a 81 in2 port it almost goes as low... And is louder! I'm pretty happy... Thanks to all, especially CSCstang for all the advice and help. http://i.imgur.com/BgrwbZT.jpg ... http://i.imgur.com/ORgaMrJ.jpg ... http://i.imgur.com/QlDIVZ6.jpg
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
12
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
558
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
727
shredder1
shredder1
AZ
shredder1
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
