Trying to decided on front stage, your thoughts?
JoshC
The Taco MASTA
2,913
Houston, tx
So i love a mid woofer the other day and im looking to replace the mids or the whole set. Heres the options ive gathered. Im trying to keep good sq while gaining some midbass over the hertz HV-165s
option 1
I can use my DD T2's on hertz crossovers with some CDT CL-6Ms in CL-6M
option 2
Focal 165 A1 SGs Focal 165 A1 6-1/2" 2-way Access 1 Series Component 6.5" Car Speakers System | eBay
option 3
JBL P660C CAR AUDIO 6.5" 2-WAY 270W POWER COMPONENT SPEAKERS SYSTEM SET 6-1 /2" | eBay
Ill be using a eclipse premium to power them, so any speaker will get plenty of power. My eclipse can offer up to about 100x4@4 if you have any other suggetions. Looking to spend a max of 160 atm
For $179.99 I can get you a pair of CDT HD-6MDVC subs that will run at 2 Ohms and play higher than the CL-6M subwoofers you linked. The CL-6M is not likely to sound good at all with that crossover and tweeter combo. Ideally you'd want to use the CDT EX-550i crossovers with the CL-6M. You get a much better deal buying a full component set than buying just mids or subs.
option 1
option 2
option 3
i love my cdt es 010 tweets they sound amazing, got the es6mo mids which should be here tomorrow. should of had the mids installed over a month ago but ups fvcked the first set up. i have another set of es 010 tweets i might be willing to sell, if ur interested brand new never been used.
You can get just the mids or them in a 2-way set? Link?
the ebay focals are fake josh ,the cdt will be your best bet ,i too can get the hd 6m dvc subs.i think either sub will work for you josh.remember i had your old comps so i know how they sound.i think what i recommended will be just fine for your needs and your price range
1 for sure focal speakers like enclosures to run to their potential
I like the CDTs and i feel like its the most solid choice, but im worried about it using them a hertz crossover. Thats why i was looking at sets
personally I like making custom component setups and hertz makes good crossovers also
older set ,no cdt warranty.also the newer ones are better
---------- Post added at 09:19 PM ---------- Previous post was at 09:19 PM ----------
only 50 rms each channel tho
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
398
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
756
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
JoshC
The Taco MASTA
JoshC
Houston, tx
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
