Trying to determine proper fuse size
  • 2
captain_cactus7
I recently got my vehicle back from my mechanic and realized he took the fuse that is connected close to the battery out and forgot to give it back. I have no idea what size it was or what size I'm supposed to use to replace it. I am running just a small 200 watt Memphis SRX1.250 system. I know it has 2 15 amp fuses built into the amp and someone told me the fuse at the battery should be the same size as those. But I went to a store to buy the fuse and the guy gave me a 60 amp fuse saying that would work just fine. So now i'm extremely confused.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
305
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
735
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
captain_cactus7
captain_cactus7
indiana
LosIsATool
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
