Trying to get 2 12s under back seat!!!
sthib
la
I'm looking for 12s that I can get under the back seat. Will be lifting the seat but just shy of getting the airspace I need. Are there and 12s that call for only 1 cube ported without hurting my output or sound.
Will be around 1200w
Also will be aero ported I know this isn't right section for port question but which way should I port and fire sub.
I am building a box for under seat of 2012 silveraldo crew cab. I lifted seat 2" using square tubing 1/4"thick. I am going sealed with two 12" Fi Q (I think or maybe ssa xcon). I will have close to 1.5 ft^3 per sub (3ft^3 total) after sub displacement. Downfiring. I don't have enough airspace for ported unless using 10". Also mounting depth can be an issue, which I will have just over 7". I have seen downfiring with port to back wall works well, but not sure.
Check back when you get it figured out. I would be interested to see what you do. I plan to do build log when I get further along and get finalized on everything.
Good Luck.
I will sure check back I'm going to be building some test boxes to see exactly what I can get! Maybe do a build log
That's what I really wanted I use to have a lvl 4xl and loved it. But I'm having trouble designing a box with enough air space for the 12s
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
409
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
758
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
sthib
sthib
la
EdMan71
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
