Trying to un**** the install done by previous owner
  • 3
dvrmstrng
DE
Just picked up a 2001 Tahoe for a daily and am losing my mind trying to get the audio system functioning.
Currently it has an older Panasonic BT Double din
Mix and match speakers in the doors
A rear factory sub that isn't working but a factory amp that has power.
Does anyone here have any experience with similar vehicles, I believe most Tahoe's Suburbans and Denali's have a similar setup. If someone wants to PM their name on FB I have photos of basically all of the wiring saved for easy sharing. Thanks.
You can try to upload pics here with PB. I didn't have any issues the other day when I uploaded a few.
As to your problem, either sub is blown or simply needs to be plugged into the amp again.
I have a 2001 Yukon XL 2500. When I got it the aftermarket system was not done right. I ran 12 gauge runs from the back, through the door grommets and used these for my door speakers, bypassing the factory speaker harness. Ripped out the 8 gauge CCA power and ground cables installed by the previous owner (the positive had a 15a fuse under the hood that was melted into an open circuit), that was powering a 500 watt amp. Ran new power, ground and RCA cables. Basically just tip everything out and start over.
Sent from my LG-H910 using Tapatalk
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
562
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
3K
dvrmstrng
dvrmstrng
DE
JDay
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
