Tundra system help
  • 4
pbplayer
Going to be running a pair of sundown sd3 tens. Also planning on changing speakers at a later time. I was thinking about running a sundown 1100.5 to power everything. With this be enough for then subs or should I get a mono amp for now and a four channel later.? Not sure what the sd3s can handle and if the 800 Watts will be enough.
What year Tundra?
You may be better off with a DD D5.1000, SD3's handle 500W Rms and the D5.1000 is the only 5 channel I know that puts out 1000WRms on the sub channel.
2014
Ya I wanted to see what others are running as far amps go I don’t have to have a 5 channel but figured it would be easier. I will look into the DD as well but I know I don’t have a dealer very close by.
Double Cab or Crew Cab? I have a 07 double (first year of current Gen) and if you go underseat those SD3s may be a ***** for you... I found over 4" mounting depths unable to fit.
Going behind the rear seat in my crewmax.
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
995
Hey there - New on here as well and also a new Tundra owner. I have a 2021 SR5 and sadly they have not updated the stereo since before your model...
24
3K
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
9
The L7S are 1500 combined and I’ve got 1200 currently, so I need a larger amp. I have voltage drop with the 1200 when I’m pushing them
6
949
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
265
pbplayer
pbplayer
carroll,iowa
Boomin_tahoe
HandsomeSteve
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
