Two 12" Image Dynamics IDQ12 D4 V.4
  • 2
Image Dynamics IDQ12 D4 V.4 (Two of them, but will sell individually if desired)
These are two lightly used, *Pristine* condition Image dynamics IDQ12 D4 V.4 subwoofers.
Manufacturer specs -
Subwoofer Series IDQ V.4 (Image Dynamics)
Subwoofer Size 12"
Peak Power Handling 1500 watts
RMS Power Handling 750 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
Sensitivity 87.22 dB
Xmax (millimeters) 17.00 mm
Subwoofer Design Round / Circle
Main Cone Color Black
Woofer Composition Mica Injected Polypropylene (MIPP)
Woofer Surround Nitrile Butadiene Rubber (NBR)
Subwoofer Grille No
Re-Cone Kit Available No
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Sealed
Optimum Sealed Box Volume 0.90 cubic feet
Optimum Ported Box Volume 1.50 cubic feet
Top-Mount Depth 5-13/16"
Cutout Diameter 11"
Shallow Mount Installation No
These are $230 EACH new. I am selling these for $100 EACH. I will pay $25% of shipping
I will pay 25% of shipping.
https://www.dropbox.com/s/aw971d55udfmooa/IMG_0688.JPG?dl=0
https://www.dropbox.com/s/nfbkcbfig2twz64/IMG_0684.JPG?dl=0
https://www.dropbox.com/s/nv6w5uu5otj8f0o/IMG_0685.JPG?dl=0
https://www.dropbox.com/s/0py8u6hotbfwlsq/IMG_0687.JPG?dl=0
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Try to reset again and if that doesn't work, try updating the firmware. To update the firmware for Alpine X800D, you can follow the instructions...
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
3K
Bonusfeatures75
NY
Bonusfeatures75
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
