two 8's or a single 12. Low power.
IsThisTaken
I'm building a budget setup and I need help deciding. I want to run under 500 watts rms for the sub(s) since this car is tiny and the stock electrical is weak. I listen to a 40/60 split of rap/indie rock. So I'm looking for a musical sub that can handle lows reasonable. I currently own a Kicker ZX400.1 mono amp which will produce 400 rms at 2-ohms. I was originally going to get an SSA Dcon, but now I'm considering two Sundown Audio E8v2's.
What do you think? They are rated at 200rms each, but I have heard virtually nothing about them. Which setup would you choose? The two 8's or a single Dcon 12.
I would suggest the 12.. it doesn't necessarily need to be a low powered sub if you put it in a highly efficient box it will perform well.. a tline is a good example if you have room.. a 4th order/6th order etc
anyone else have input? seems 50/50 at this point. While I know sundown is solid, im just not sure if those 8's will give good sq or be able to handle the music I like. I know the SA8's can but these Idk.
IDQ's aren't that power hunger and are very musical. I had a IDQ v2 in a 1.25 (predisplacement) and it sounded great. I had a bridged amp rated at 600rms @ 4 ohms. It was wired for 8ohms so I was actually running closer to half that. It probably wont rattle your car like a sundown. I traded it out for an SA12 and it didn't hit much better that the IDQ in the same box. It was a little more deep not nearly as musical though. I am thinking about swapping back, but since bought a new amp that is pushing 1K at the SA12 it is much better. Still not quite what I thought it would be. Maybe it is my setup or I am expecting too much?
In a low power system the enclosure will make a huge difference in the performance and sound.
As for your questions, I would go with a single 12.
Iwould go with one heavy 10 myself,yet,//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif 12
Id go with a pair of Image Dynamic ID8's. Toss those in a 1.4 cube box tuned at 34Hz and be happy. They get low, dont miss a beat, and sound fantastic. At WooferWarehouse you can get them brand new for $80 a piece plus they have a coupon code to save even more.
****. those id8's sounds like a good idea.
okay. I'm between the dcon 12 and the ID8s.
I'm looking for something that can get reasonably low as well as high. I plan to cross my subs at 100-120hz.
which do u think are best for my goals and music taste.
****. those id8's sounds like a good idea. okay. I'm between the dcon 12 and the ID8s.
Using subs from 100-120hz is a waste of time. You might as well build a really nice front stage with sound deadener and closed cell foam up front.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
497
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
774
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
954
IsThisTaken
IsThisTaken
Wisconsin
DoesDad
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
