Two kicker comp 12's one Alpine Type R 10
Kicker comp vs alpine type r
  • Kicker comp
    Votes: 0 0.0%
  • Type R
    Votes: 8 100.0%
  • Total voters
    8
Forgot to say my truck is an extended cab ranger and I have two twelves in it being Pushed by a 1000 watt Sony xplod amp. One sub is a pioneer one a Sony xplod,both simple walmart subs, but they beat in my truck. There in a huge sealed box that is squeezed in my back seat area.
The smaller cone area ported will be more impressive for what it is. Type R are good for the buck, so are comps however and 2 12s is a ton more cone area than 1 10; even sealed vs ported. It's all a preference. Ported just sounds better to me, and again is more impressive for what it is. Voted Type R in this instance.
I'd say Type R for what you wanna do. But if you've got the room for the Comps they can get loud on real low watts. Had a pair in the wife's minivan. Was pretty impressed for 300 watts.
Don't mean to post jack but would 1 woofer ported vs 2 woofers sealed generally have more output or does cone area usually win out if you have identical woofers??
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
526
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Jordan Lay
Jordan Lay
Carbondale Illinois
BoomBoxStereo
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
