Ultra budget sub build $250
Do not set the amplifier's gains to the max. If you're setting the amplifier gain to the max, either your amplifier is just not good enough to drive a subwoofer or you have a pretty exagerated bass that's far more than is necessary to blend with the fronts or there is some other problem (phase issue, etc).
Setting amp gain to the max is a great way to send a clipped signal to the subwoofer. In general, I prefer to calibrate the front speaker's amplifier gains such that when the head unit's volume knob is at about 75%, that's my normal listening volume. The lower you set the amplifier gains for a given music volume the better. Once I am done with the front stage, then I turn on the subwoofer and adjust its gains to blend the lows with the front stage.
I definitely "have a pretty exagerated bass that's far more than is necessary to blend with the fronts" because I like that and think it's fun. The clipping lights on the amp never go on.
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
4
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
6
I loved US amp back in the day. worth the investment
4
Euthyphro
Euthyphro
LA CA
sacsking916
Decebal
    Jun 10, 2024
