Uninstalling a aftermarket Euro Din Reciever
  • Thread starter <DrewJ>
  • Start date
  • Replies 1
  • Views 2K
  • 1
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
658
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
765
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
Guest
Boominburban
    May 18, 2024
    May 18, 2024
