UPA model 12.2 and 12.4 subwoofer details **PRE ORDER AVAILABLE**
  • 4
Under Pressure
Tampa, Fl
Speaker PRON!!
View attachment 26547467View attachment 26547466
View attachment 26547463View attachment 26547464
View attachment 26547460View attachment 26547461View attachment 26547462
As promised here is some more info i am sure your interested in:
The UPA 12.2 and 12.4 models
  • ***PRE-ORDER***
  • ***Estimated Arival date May 26th-30th 2014***
  • (already in production)
  • Nominal diameter: 12 inch
  • Rated Power: 1000 W *RMS*
  • Impedance: 2+2 & 4+4 ohm dual voice coil configurations available.
  • Frequency Response: 40-1.5 kHz
  • Voice Coil diameter : 3" Dual layered spiders
  • Voice Coil material: Copper for heat resisting
  • Magnet size: 460oz /3*190mm
  • Magnet material: Ferrite
  • Sensitivity : 86dB
  • Basket material: Sprayed texture aluminum.
  • Paper cone: Paper
  • Edge material: Foam
  • Suggested ported box size 1 to 1.25 ft^
  • 1 Year limited warranty
  • Prices Include shipping!!
    ****$259****
Go to www.UPAudio.net for full details and to add this to your cart!!
**PREORDER SALES ARE FINAL**
More info to come very soon. Hope you enjoy this little teaser till we get some vids up!!
If you have any questions please feel free to contact me at:
Sales@UPAudio.net
Thanks for looking all!!
Yes def a 15 is next. Same 3 inch coil 460 oz motor, 25% thicker Tinsels. Later down the road will come the 10 inch size, before i move onto a 4 inch vc monster line. But 1st things 1st. If i am worthy enough to be viable in the market. I have many projects on the back burner. Such as high end comp sets, custom earbuds and a few more things i think would be greatly accepted by the community.
Thanks for stopping by!
Evan
Will have them up today, tonight at latest. Been dropping tones on it loosening up the suspension and letting my wife ride around and beat on it so we can see what this big booty girl can do. My daughter just had her military ball so it delayed me a few days but were back on it!!
Stay tuned and thanks for lookin!!!!
With this proto model i had changed a few things from previous models they were geared more for spl. Although I was trying to find the common ground. So i had the engineers soften the spiders some add higher roll surround to try and we got the Fs to 39/40 straight out of the box. Ill have more accurate numbers when i dats the sub after this "break in" period to see if it helps lower it some which i believe it should.
As for the box? So far i have played it in a box tuned to 36, 34, and 32 ish box and it played well. On o-scoped power. 34 so far has been the nastiest.
The 1k rating is a conservative rating.
Under Pressure
Under Pressure
Tampa, Fl
Under Pressure
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
