update firmware on avh2300nex
  • 3
youdoofus
Skibidi
so, the instructions say that the parking brake must be engaged, so i went and tried to run the update since i have that bypass module attached. Well, it must be that the system requires the parking brake to be engaged for x amount of time because the update firmware box never lit up as a pressable option. I tapped it repeatedly since the bypass module sends pulses of ground to the unit to simulate repeated parking brake engagement and disengagement to fool the deck into thinking that you have done the dumb pattern it requires to be able to play video. Does anyone have any experience with updating the firmware with one of these bypass modules installed?
The update has to be the only thing on the flash drive and it has to be in the specific format specified.
I had issues on my avh-x2800bhs but I never had to undo my bypass.
thanks for chiming in man. Ill reformat the drive i used again and put the .avh file. I guess i do kinda like how they put the file in a .avh format to mirror the model number of the deck, but it just seemed a bit weird when i unzipped the .zip. Mul old home made bypass consisting of a relay that required me to press source on the deck to turn it off which triggered the relay to disengage then turn it back on which re-engaged it would have been a dead lock. My main concern is that the update button never lit up for me to select it
Found the fix just needed to get a usb correctly and reflash fully working
I would get some caulk/ Silicone and seal every crack and crevice and screw splits inside and outside. Everywhere
8
83
@audiobaun @Doxquzme Yall got me excited!!!!
14
878
I recently tried this stuff and it seems as good as the Duratex I've used prior. It's almost half the cost too...
I just clicked on six separate threads and they went well. Seems to have worked.👍
9
982
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
