upgrade from hdc3 12?
so i currently have a soundqubed hdc312 on a Saz1500v3. gets very loud don't get me wrong, but just doesn't have that deep low bass i was looking for. seems a little hollow. wondering what single 12 would maybe suit me better? box is 2.5 cubes before displacement tuned at 35hz
I would definitely try a new box first, tuned lower. That setup has a lot of potential. What impedance is your sub? That amp can be wired to .5 ohm if you have the electrical for it. I have the 1500dv2.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
472
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
590
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
783
ATC_DJ
ATC_DJ
Montgomery, AL
ATC_DJ
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
