Ups/downs of class A/B or D amps?
Supergumby5000
Project: F350 begins...
8,560
Pullman, WA
Other than efficiency, is there any benefit or loss when comparing class A/B amps to class D amps for a substage?
reason i ask is im looking at some amps, which i want to be matching between my speakerstage and my substage. I need about 800rms. the amps i am looking at have a 1000rms class a/b, and a 1500rms class D.
I dont need 1500rms, but will i really notice a difference in a substage in terms of efficiency? the sub in this setup is rated for 600rms.
its partially the efficiency rating, but also the efficiency when in use.
class D tends to be pretty efficient from 10% to 100% rated power.
class AB tends to have ok efficiency at 100% rated power, and really poor efficiency at lower output power.
the result is that turning the volume down might not reduce the system's draw by as much as expected. this can be annoying if the electrical system is susceptible to heavy loading.
I've noticed that a big part of this subject is the tuning of the amp, and the music used for tuning. when you try to overemphasize certain qualities, you can get poor results. try listening to a variety of music with punchy bass, deep bass, generally loud bass, ect... the above can be true if you tend to re-tune your system, as you'll tend to optimize it to sound the best with the music you're listing to at that time.
great info, thanks.
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
  • Locked
Hello and great day to all of caraudio.com family . So I'm here looking to see if anyone may know of someone wanting to sell there steg msk 50sc...
Ok , to answer your question about the counterfeits yes , so sinfoni sold rights or lost the rights to a chinese company a few years back and so...
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
10K
Supergumby5000
Supergumby5000
Pullman, WA
Jh8909
Decebal
    Jun 10, 2024
