US AMPS AX3200DE needs work. 3kw cheap
  • 5
bigblackdodge
As title states. Us amps ax3200de needs work
Used and needs some repair. Burnt FETs and possible power supply. I was gonna use it on my 4 12 obsidians but never got it repair and totaled my dodge along with the sub's. Worst day ever! Anyways since I got it from bassaddictj I haven't done a thing to it but replace the plexi bottom myself. In the pics I tried to get a good pic of the only kinda bad cosmetic damage on it where the clear coat is scratched and bubbling. Very minor but still..... And I got it without a couple of setscrews which was no big deal so I got some from fastenal and put them in place all matching. Repair will run 200$ give or take sum. Should be less though.
Price: 230$ shipped insured with tracking.
Or trade for a working 1400-2500 watt amp 1 ohm stable. Large window of wattage. Just depends on make and model. If its a 300$ amp you have I will pay you the difference... Love a ct sounds 1400.1
On me. Unless cost is 31.00$+
Doing this on my tablet so idk if the pics uploaded on here if not I'll find how to post them.
If it was 200 to fix plus 230 for purchase you would have round 450$ in a solid banging ace amp. Last of the handmade/ us made us amps amplifiers. Underated and good clean power. I have the PDF owners manual that shows the specs. 1200@4. 2000@2 and 3000@1ohm. Takes a 300amp inline fuse. Guarantee to make more than 3k. Us amps always under rated their amps.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
453
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
576
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
bigblackdodge
bigblackdodge
Morven, Ga
big bass joel
Decebal
    Jun 10, 2024
