Us amps usa-50hc (2)
#1Tunna
Papio Slayer
US AMPS USA-50HC
At least 8/10
In really good condition for its age, only real con is some light overspray, easily removable. Came like that from the original owner. Will come in original boxes from factory. Only have 1 manual so first come first serve or its obviously yours if you buy both:)
$140 shipped per
$260 shipped for both
Prices are firm. Will accept trades for a nice 6.5" component set.
Included
Specs:
US Amps USA-50HC
2 x 25W @ 4 Ohms
2 x 33W @ 3 Ohms
2 x 50W @ 2 Ohms
2 x 100W @ 1 Ohm
2 x 185W @ ½ Ohm
1 x 100W @ 4 Ohms bridged
1 x 132W @ 3 Ohms bridged
1 x 200W @ 2 Ohms bridged
1 x 375W @ 1 Ohm bridged
Fuse: 75A
GLWS!! Clean amp
I collect US Amps. The manual you have is from the early 90's. The amps, judging from the boards, are the 1999 version. The board should be the same as the USA-150/150X. The rail voltage on the USA-50HC is +/-15V @ 35A. The "white pages" for that amp say it's 100W/CH @ 4 ohms and the overage factor is 15:1. It has (12) 125W 3MHz bipolar transistors. Doing the math in the US Amps brochures 15V x 1ohm = 15A...15V x 15A = 225W/CH. Bridged is 30V x 1 ohm = 30A...30V x 30A = 900W. Someone correct me if my math or way of thinking is off. US Amps are way underrated. GLWS!
Thanks guys, they've been good to me. Glad to have owned these amps but they have to go, got a AQ120.4 to go active, couldn't resist with the Black Friday deal they had going on.
Hmm, maybe ill just keep them and run 1 per coil on my 12. Haha, nah. Gotta get these sold guys, been out of a job for over a month and having a hard time paying bills. Bump it up!
215
446
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
#1Tunna
Papio Slayer
#1Tunna
Wailua, Kaua'i (HI)
oldschool69
    May 20, 2024
    May 20, 2024
