Us amps vl-400
mclerico83
tampa
VL-400
Scratches bumps. Original feet are missing on wires side.
2 x 100W @ 4 ohms
2 x 200W @ 2 ohms
2 x 400W @ 1 ohm
2 x 600W @ ½ ohm
1 x 1200W @ 1 ohm bridged @ 12 volts
THD @ 4 ohms:
S/N Ratio: 115dB
Damping Factor: >1000
Fuse: External 225A
500 shipped
included
Sent from my 2PYB2 using Tapatalk
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
415
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
550
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
mclerico83
mclerico83
tampa
mclerico83
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
