using a capcitor does help..........
wishbone
NJ
If you are someone whom has been convinced that a capacitor doesn't help, I have proof it does. After installing one in my mini van yesterday I immediately noticed the sound comming from the subs was enhanced greatly. The dimming of the lights on the radio, head lights, and instrument panel stopped. I am running the wrong awg wire from the battery which also contributed to dimming but, with the capacitor supplying voltage and current directly to the amp, helps bypass the wiring problem. I was told 1/0 wire isn't needed for the 1200 watt system I am trying to accomplish. Actually I was told 4awg should be more than enough. So before running out buying extra batteries and geting 0awg wire, look into buying a capacitor. Besides it can't hurt to have one even if you think it's not working.
WB
WB
A capacitor is an extra hassle on your charging system. Unless you have a proven double blind test that proves the cap is truly a diffrence, STFU.
What your ear thinks it hears under the perception that your capacitor has just made your crap subs into JL Audio W7's is irrelevant data.
WHY YOU DONT NEED A CAPACITOR
In Other Words Dont Waste Ur Money On Garbage
The following is a series of excepts from CarSound written by Richard Clark which examines capacitors in every detail. Read first...then ask questions.
Lesson 1
Ok “powertrip” how about we have a discussion in basic electrical theory? At the end of this thread you should be the one that can explain to the world that according to ohms law it is impossible for these things to do any good. That is of course if you can admit that they do obey ohms law. We will do this a little at a time so how about you humor me and stick to my questions. We will do them a couple at a time so everyone can follow along. Let’s do a little calculation. Suppose we have a resistor that is .017 ohms (seventeen milliohms). I think that is what you say the ESR of the giant caps is.
The ones I have seen have measured higher but I will give you the benefit of the doubt. According to ohms law how many volts are dropped across .017 ohms if 100 amps of current are flowing? How about if we up the current to 300 amps? Let’s establish the answers to these questions before we go any farther. If we can't agree on the answer to this there is no hope we will ever get to the truth.
Lesson 2
Thanks David you are exactly right. If anyone wants this explained please ask David to clarify it. If everyone is going to follow this and understand fully the final conclusion it is important that no one miss any steps. There will be about ten lessons. Since power trip has left the building we will continue with the rest of the class. ESR stands for equivalent series resistance. This means exactly what it sounds like. It means that if we have a source of voltage it will behave exactly as if it has a resistor of the same value in series with its output. An amplifier has ESR, a power supply has ESR, a battery has ESR, and yes, a cap has ESR. Components have ESR’s because we do not have perfect conductors to make things from.
And now for the homework. Last night we learned that if 100 amps flows through .017 ohms there will be a voltage drop of 1.7 volts. And if the amp flow increases to 300 amps the voltage drop will increase to 5.1 volts.
For the sake of theory only let’s say we have built the largest cap in the universe and it has billions and billions of Farads. Its plates are made of a newly discovered material we'll call unobtanium. This new material has no resistance therefore our super cap has an ESR of ZERO ohms. We then charge the capacitor to 14.2 volts. We then place a resistor with a value of .017 ohms in series with one of the terminals of this cap. The question is: If we place a load that draws 100 amps from this cap what will the resulting voltage be on the load side of the resistor? What will the voltage be on the cap side of the resistor? What about if we increase the load to 300 amps? What will the voltages be on each side of the resistor?
Lesson 3
Ok now that we have studied ESR and understand what it is and it’s effect on the working of a circuit we will move on to another subject. But don’t forget about ESR as it is one of the important final building blocks in our search for truth about caps and we will come back to it. Today we will review the important concepts about total energy storage in a device like a cap. This has been covered in earlier posts (and I will say quite correctly) but I am going to expand on it as well as reiterate it for those who did not get to read it. Besides, I think I can simplify it a little.
In electronics, we measure power in watts. Wattage tells us how much work a device can do. But a wattage rating does not tell us anything about how long we can sustain that work. When we add the element of time to our wattage, we use a value we call Joules. A joule is a watt second. This means that one Joule of energy can provide a watt for a second. Ten joules can provide a watt for ten seconds or ten watts for one second or five watts for two seconds one hundred watts for a tenth of a second, and so on.
The formula for determining the total joules stored in a capacitor is very simple. We take one half the capacitor’s value in farads and multiply it times the squared charge voltage. For example a one farad cap charged to 14 volts would be .5 X (14x14) = 98 or .5 X 196 = 98 Joules. A 20 farad cap charged to 14 volts would be 10 X (14x14) = 1960 Joules.
There is a very important concept to understand about energy storage. A capacitor actually stores electricity.
Batteries don’t. Batteries have the potential to produce electricity by means of a chemical reaction but caps actually store electrons on their plates in the form of an electrostatic charge. In our next two lessons we will learn why this is important to know.
But first, the homework. This is a “think about it question”. We have learned that a Joule is a watt second. A Yellow top battery is rated at 65 amp hours. This means it can provide 65 amps for an hour. The question is how many Joules does this represent? Since this is a thought question, it would really help if whoever answers would show us your math.
Lesson 4
In the actual real world the voltage of the battery would drop a little from its open circuit voltage of 12.8 volts with a 65 amp load. In the case of the yellow top its actual voltage at 65 amps is about 12.2v when fully charged. By the end of the hour it would be down to about 10v. If we use 11 as an average our answer would be........ 2,574,000. Now that's still a lot of joules! Now actually this is not enough to totally kill the battery but at this point there isn't much left in it. This brings us to a very important fact. The energy in a battery will be depleted almost completely by the time it is down to 10 volts.
Lesson 4 (continued)
By the time we have removed those 2.5 million joules from the battery it probably doesn't have more than a hundred thousand joules left. We can almost totally deplete the battery's energy and never drop below 10 volts. This is because the battery doesn't store electricity. It stores chemicals. A chemical reaction produces the electricity. Storing actual electrical charges is very inefficient.
Look at our poor capacitor. Even if we made one as big as a battery it would still only be good for perhaps fifty to one hundred thousand joules---less than that left in a nearly dead battery. But if that were not enough there's more bad news. This exercise will be tonight’s homework.
A capacitor is like a gas tank in a car. The pump can only remove gas down to the pickup point. Any gas below this point can never be removed by the pump. If we charge a 20 farad cap to 14 volts we know from previous lessons that it will contain 1,960 joules. If we use that cap in a system and load it till it drops to 10 volts along with our battery how many joules will we have removed from the cap? How many joules will remain in the cap that we can never benefit from if our system never drops below 10 volts?
Lesson 5
In our last lesson we learned that caps actually store charges on their plates. And of the 1960 joules stored in a 20 Farad cap, 1000 of them sit at a potential below 10 volts. This means there is no way they can ever be used by an operational audio system. Today we will look at another loss factor. It has to do with the loss factor due to the ESR of the cap.
We have already studied voltage drop due to ESR but now let’s view it from an energy/watts standpoint. Let’s clarify things. The power delivered to the stereo by the battery and alternator bypass the cap. They merely flow by its terminals. If the cap charge is lower than the battery/alternator potential current will flow INTO the cap until it reaches equilibrium with the Battery/Alternator. If the B/A potential is lower than the charge potential of the cap current will flow OUT of the cap to the battery and or the amp.
Always remember that voltage always flows from the highest potential to the lowest potential, just like water. Current does not however flow into the alternator even if it is lower than the battery and cap because it has diodes on its output that only let current flow FROM its output. Now whenever any current flows into or out of the cap it must pass thru the ESR of the cap. The resistance is really distributed throughout the cap but it behaves just like it was right on the output terminal as in a series circuit location in the circuit loop does not matter. Now suppose our 20 farad cap is charged to 14.2 volts and we place a load on its output. This load is the same one that we used in lesson 2 to cause 100 amps of current to flow from our unlimited capacity cap. Only now we have our smaller 20 farad cap.
WB
stfu stupid... next time make a post worth posting... //content.invisioncic.com/y282845/emoticons/hitbybrick.gif.68a672fae224041f00769a97c2c1bf2d.gif
WB
Lol, you are wrong on many points there.
And yes, it can indeed hurt to have one.
I have a big ass alternator and doing 3Krms, no cap, my lights don't dim //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Even before on the stock alt, and big three upgrade, no dimming.
So to all of you numb nuts out there, who think you know more than what is obvious, please explain why the mere amplifiers you run in your bass only pounding systems have capacitors the size of c and d size alkaline batteries, if capacitor don't assist with providing consistant power?
WB
PS no dumb, smart ass answers please.
did you try any of the big 3, esp the battery negatvie to chassis wire
I didn't have to. All of the big three are last resorts, besides I just told you installing a cap took care of the problem I was trying to solve.
Calm down with the SHUT THE F UP NONSENSE I am just going to ignore you any way.
OP, you are not going to win. You should have just kept your thoughts to yourself. Now, you will get flamed to the point of crying. Youll get mad and trade insults. In the end you will still be wrong. Maybe you will get so mad that you kill yourself. If thats the case then by all means, carry on.
WB
Uhhhhh //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Did You Not Read Post #3??? Damm //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif Now go pop your trunk and //content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif your Capacitor if not then //content.invisioncic.com/y282845/emoticons/youreawesome.gif.a27e190c662afa8e2be5686b27bd1659.gif for keeping it...
beat me to it tapout. u really have no clue about amps, or the capacitors within them. why would u bring that up in a forum where u are surrounded by tons of people who are much, much more intelligent/informed/experienced than u. caps do nothing but add impedence, lower voltage going from ur batt to ur amps, and make ur ride look like u bought it at walmart. led voltage light ftmfw...//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
So you are basically calling me a liar ? t you are saying the cap I installed did nothing to enhance my system ? If you can prove this in the next 10 minutes I will buy you what ever amplifier you want. DEAL ? or NO DEAL ?
WB
I don't believe the OP. Unless he can provide scientific evidence with actual numbers, his perceptions are totally useless!
ETA: I have successfully used a capacitor to get rid of an alternator whine that had myself and multiple "professional" installers stumped. One of my friends who was in California at the time recommended that I try a cap to get rid of the noise because they filter out the high frequency garbage from the power line. I'll be, he was right!
934
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
761
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
9
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
4
wishbone
wishbone
NJ
audioholic
Decebal
    Jun 10, 2024
