Using car audio in the home?
you can do it, ive tried it, but just not for an extended period of time. I had an extra car battery,amp, charger, and 10" sub lying around in my garage.
Wire up the amp to the battery, and and the amp to the sub. for RCA's i just ran a set from my surrond sound in my room. i only kept it running for a bout a day though. Never gave it a good shakedown.
Cheap plate amp would be a better bet probably. Only problem is JL's great way of making the ohm load different from everybody elses. Either way, a nice plate amp should cost about $125-$200 and give you enough power for tight, college living.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
Hey guys didn't realize this thread got revived. Decided to bite the bullet and buy a used Yamaha receiver. 6 channels 100 wats per channel with...
13
933
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
760
I hold firm on the deposit in all situations 😎
9
IowaBoomer
IowaBoomer
Walnut, IA
Heresy
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
