Using Toslink or RCA for signal distribution
  • 1
heedicus
CarAudio.com Newbie
Pardon my ignorance as this is the first system I have put in a rig for about 20 years, so all the technology is new.
Here is my plan-
Factory head unit in a '17 F150
all JL Audio
Fix 86
VXiHUB
VXi-600/6
4x C2-650x
2x C5-075
VXi-600/1
10w6V3
The question is:
If I swap out the Fix 86 for a Fix 82 I should have Toslink outputs that I could run into the VXi-Hub which has a digital distribution block. Then use the Toslink to send audio to both amps separately. But if I do that it only comes in as 2 channels so there would be no fading capability?
I plan to use the TuN app to tune the system once installed.
What else am I missing here?
Thanks
733
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
592
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
9
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
4
heedicus
CarAudio.com Newbie
heedicus
Eagle, ID
heedicus
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
