UTV soundbar goes into protect mode on engine start up.
  • 1
Cwheels333
CarAudio.com Newbie
I recently installed a Inifinty Kappa 4100msb sound bar on a Polaris Ranger 1000xp.  Sound bar seems to function fine however when I start the engine it turns off and the LED’s flash white.  Per the instructions “The soundbar is in protection mode due to overcurrent, overvoltage, undervoltage, overtemperature or DC offset.”  I am thinking this is because of under voltage as the voltage drops down to 10.4 or so volts when the engine cranks.  The light flashes for 10sec or so then the unit comes back on and everything is fine.  When the the engine is running it puts out around 14 volts.  I installed a cheap capacitor from Wally World (500k micro farad) thinking this might fix it but still having the same issue.  Can a better capacitor fix this or is that not how they work? Any help or solution is much appreciated!
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
984
Hi Ferdi.. Yes I have had a brand -new DMX5020 installed last week and it does almost as you described. Once the phone is connected it's all...
I'd try wiring the subs to 4 ohm (series parallel) and see if that makes the problem go away.
5
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
Cwheels333
CarAudio.com Newbie
Cwheels333
Cwheels333
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
