Very Weird Deck VS Headlights Situation
  • 3
Jesse059
I am having a very weird situation with a deck i installed a few days ago. I bought a Pyle PLTS79BT 7-Inch Single DIN In-Dash Motorized Touch ScreenDVD deck (Regrets i know the name pyle says it all //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...) But anyway other then the radio being a piece of junk everything works one hundred percent... Or so i thought
Now I don't know if i had to or not but i took the video bypass the one where you have to tie into the emergency break to watch movies and just grounded it off under the dash. Every single thing works i can go anywhere i want and watch a dvd while driving (I don't) but just says it works, or do anything with no problems... During the day.
When i turn on the headlights. Done. The whole deck just locks me out and says "CAR" i cant close it shut it off nothing. Turn off the headlights. Instantly get everything back.
So does any one have any ideas what the heck can be going on here? Thanks to anyone in advance for some help.
Sounds like you wired the harness improperly. There should be a wire labeled "illumination" or something like that. It is meant for when you drive at night and turn your headlights on, the H/U dims so it isn't so bright. Sounds like you mixed that wire up with something else. That would be my best guess.
That or because your Canadian. Its a toss up. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
951
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Jesse059
Jesse059
Calgary
chillin
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
