viper amps ??????
  • 3
shane zettle
hello i have two viper amps that were pulled out of a veh that i sold... the friend did not get the plugs that go with the amps. dose anyone know where to get these i have tried dei,ebay and so on. my amps are a 150.2 and a 300w mono sub amp. and is there a way to make ur own wiring that u can plug into these amps thanx for reading and i am looking forward to ur reply..
피크를 사용하지 않을 계획입니다.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
153
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
414
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
shane zettle
shane zettle
spokane wa
akheathen
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
