Viper Issues
John3000
Georgia
Ok, now that it has been getting insanely hot and my viper is mounted in the trunk I am having a problem. When I get into my car and crank it up and turn on my system, the viper is in protect mode, I assume it does this because it is hot as hell in my trunk. Anyways has anyone ever put a fan on their viper and if so, what size fan and how did you hook it up? I am new to the whole put a fan on my amp thing so any suggestions/instructions would be nice!
Thx! //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
just open it up. get a few of these;
http://www.allelectronics.com/cgi-bin/category.cgi?category=220&item=CF-208&type=store
and hook them on the inside of the amp to the REM terminal, and the ground. but just to be safe, id hook your REM line into a relay and then out to your amplifiers if you got several items off the REM wire.
but its quite simple. mounting? just use a hot glue gun, and glue the corners of the fan down //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
these would prolly be even eaiser to fit inside the amps
http://www.allelectronics.com/cgi-bin/category.cgi?category=220&item=CF-164&type=store
take the bottom of the amp off and use plexiglass both so u can view the amps internals and you can cut it to put fan(s) in
Thats what the gaming pcs use in the side pannel since its plexi glass //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
피크를 사용하지 않을 계획입니다.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
680
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
John3000
John3000
Georgia
John3000
Decebal
    Jun 10, 2024
