Voice Command In-Dash GPS With XM Radio
  • 2
MPierce2690
I have a relatively stock Chevy Cruze with an in-dash touchscreen entertainment system with XM radio, as well as a voice-command Garmin GPS. I'd like to consolidate this into one in-dash system that I will be able to use as a voice-command GPS as well as still have access to my XM radio. Ideas or suggestions? Thanks in advance!
You can keep your factory deck and there are many options to upgrade ...and add amps and other speakers to it...keeping your decks features
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
486
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
873
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Deff be a disaster and quite a shame blowing a freshly repaired amplifier in a few min.LOL. Id be very upset for sure. id recommend the wiring...
23
MPierce2690
MPierce2690
Austin, TX
Louisiana_CRX
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
