voicecoil wiring options
I hate to jump in but this is an issue I have also.With my ARC amps I have 120X2 @ 2ohms
or 240x1 @ 4 ohms
I wanna run IDQ12 DVC subs (1 amp per sub)
can I wire it either way..2ohm style or 4ohmstyle and is either way more prefferable??
Assuming the sub is 2ohm/coil ( //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ), then yes, you can do it either way. Usually it is easier to just wire the coils in series and bridge the amp.
thank you Very much //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
ima get prolly some kinda 700 watt mono 2 ohm amp for the RE SE 12'' i want.
Okay just lost my whole nicely written post.
Okay my question is can i run a Audiobahn alum10q with an aura amp. the sub is 6ohm dvc. the amp can run 160rms at 4ohm. could someone let me know if i can hook up bot voice coils or not off this amp? all info is appreciated!
amp info-
S/N @ 4ohms: >90dB
Frequency response: 20Hz-20KHz min
Channel separation: min 60dB
Slew Rate: 60V/usec
Damping factor: 60
Continuous Power Output class AB
RMS power
RMS power
RMS power
Active crossover: continuous (HP/LP/Full)
Crossover frequencies: full/50-250Hz
Cant find info transfer on the sub.
Thanks
Danny
is this possible ?? check attachment , its a 4 channel amp , bridged to 2 channel, i know i can connect each channel to a Voice coil, but i need a 2 ohm load for more power out of the amp.
i know its better to wire to each coil, and set the gain equally, but i still wanna if its possible or not . thnx:help:
Okay i take it that wasnt to help me. or was it? my main concern was the 6 ohm rating on the sub. And if i could run it and not push it full power? sry im lost once again been out of the scene to long
Thanks
danny
In the diagrams it shows all the wiring ending up to one source. Even if there are two subs there always turns out to be only one set of 1 pos and 1 neg. So does that mean that you can bridge the amp to that one set to as long as that amp handles that final impedance in that last set?????
hey everyone. i was wondering if i could get some wiring help. i'm getting 2 kicker 12" L7's and a vented box to mount them in and right now i have a small amp (punch p2002). i was wondering if anyone could help me with the wiring of these subs? i plan on selling this amp and getting a more powerful one eventually. please help?? thanks to everyone's input.
ok, how about a DVC 8ohm sub at 2 ohms? i doubt it, i think you can get it to 4 ohms with no problem.
i do have 2 of them, so maybe i can drop it to 2 ohms with a mono amp?
so, can i get 2 ohms from a single DVC 8ohm driver?
OR
can i get 2 ohms from (2) DVC 8ohm driver?
this was not listed in this thread yet.
8ohm DVC's can be wired as 4ohms or 16ohms only.
2 8ohm DVC's can be wired as 2ohms, 4ohms, or 64ohms.
is it 64...or 32 ohms. i think 32 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you could also wire 2 8ohm DVC's to an 8 ohm load.
is it 64...or 32 ohms. i think 32 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifyou could also wire 2 8ohm DVC's to an 8 ohm load.
You're right, I just forgot...I have no idea what I'm thinking...it's late - like 1am ltae...night all...
mind putting up a lil diagram?
//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
ill be lookin for a 2ohm ~300w amp for my buddy now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks guys!
The Skar wire shouldn’t be too bad. You can even double up / parallel wire to increase capacity. Perhaps not necessary here, but I don’t remember...
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
115
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
364
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
358
paikiah
Wangaholic
paikiah
Seoul, Korea
tomi
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
