Voltage drop question
  • 4
Based
Louisiana
Hey I have a question about voltage drop. How comes voltage can drop from 14.4 to 13.5 for example, instead of just going from 14.4 to 12.6 instantly? If an alternator can only produce 100 amps, if you draw 90 amps will that make your voltage drop or do you have to be pulling 100 amps before seeing any drop at all?
Also what does this mean
Taramps HD3k:
Voltage Low Power: 10 , 5 VDC Voltage Maximum Supply: 16 VDC Consumption at Rest:. 1.70 Amp Maximum Consumption Musical @ 12.6 VDC 170 Amp. Maximum Consumption in Sinusoidal Signal @ 12.6 VDC: 340 Amp.
you see the decrease in voltage because the alternator cannot instantaneously saturate the permanent magnets to produce the current o there is a lag that cause the voltage to drop so it can saturate it. its called ripple current. the current increases in order to deliver the power. you need a Capacitor to help smooth the ripple..
those older caps aren't very great. with 3kw you could get away with 5 300F caps series..
http://www.mouser.com/ProductDetail/Eaton/XB3550-2R5307-R/?qs=A%2fwzytyXNHhe5n%2fLC2rGZw%3d%3d just a soldering gun and some 12ga wire between the caps and as large as you can going into and out of the caps
Capacitor is any option... most add another battery and a high output alt
Sent from my SAMSUNG-SM-G935A using Tapatalk
Taramps HD3k:
With music playing it pulls 170 amps, on a burp it pulls 340 amps.
Upgrade just arrived...SHCA Black friday sale for the win. Even more voltage drop, here I come.
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
Based
Based
Louisiana
BSchrowang
    May 18, 2024
    May 16, 2024
