Voltage dropping at amp terminals
  • 4
brandonio21
Hi all,
I have a Sony xplod 1000W 2 channel amp, and it has worked perfectly fine with my 2 kicker 15 comp subs for almost 2 years. Last week, my alternator died, and so I replaced it and purchased a new and bigger battery for my car. However since this happened, my subs would randomly cut out, so I bought new wires and a new RCA cable and replaced everything. They still cut out and now they wont even hit, at all. I don't know whats wrong. I checked the voltage at the battery with the car on and off, and its good both ways. I also checked all my fuses for resistance and continuity, and they are all good. I then went to check the voltage going to the amp to see if it was just underpowering the subs now, and low and behold the voltage read around 5.4 volts. This was weird so i took the wires out of the amp and tested them and they tested good at 12.2 volts. Does anyone know why my voltage is dropping. It only happens when I screw the wires into the terminals on the amp. The inline fuses on the 4 gauge power wire are also ok. I checked them as well. Any help would be GREATLY appreciated!!!!
Hi all, I have a Sony xplod 1000W 2 channel amp, and it has worked perfectly fine with my 2 kicker 15 comp subs for almost 2 years. Last week, my alternator died, and so I replaced it and purchased a new and bigger battery for my car. However since this happened, my subs would randomly cut out, so I bought new wires and a new RCA cable and replaced everything. They still cut out and now they wont even hit, at all. I don't know whats wrong. I checked the voltage at the battery with the car on and off, and its good both ways. I also checked all my fuses for resistance and continuity, and they are all good. I then went to check the voltage going to the amp to see if it was just underpowering the subs now, and low and behold the voltage read around 5.4 volts. This was weird so i took the wires out of the amp and tested them and they tested good at 12.2 volts. Does anyone know why my voltage is dropping. It only happens when I screw the wires into the terminals on the amp. The inline fuses on the 4 gauge power wire are also ok. I checked them as well. Any help would be GREATLY appreciated!!!!
That amp is more than likely trash..with voltage that low at the inputs...the old alt might have been spiking to a high voltage before it went out amd shorted the amp ..time for a new sub amp
That is what I thought, so I went to a buddy's of mines house, and I hooked my subs up to his amp, and they made some noise but the voltmeter was still only reading about 7.4 volts at a high when I put the voltmeter on the terminals. If the alternator did spike though, wouldn't i have noticed power loss at other places in my car as well?
So his amp in ur car only read 7.4 ? Are you sure the battery in ur meter is good? Check the battery and alt up front and check the power wire right before amd after any fuse blocks to see where the voltage is dropping. Very odd
nasty08impala is correct, i pulled the power and ground and checked the bare wires directly. and as for where the power is dropping, I checked the inline fuse and the voltage across it directly before and after is 12.4 to 12.2-12.3. the voltage before and after the fuse block only changed by about .1 volts. I honestly am not sure where the power is dropping. :/ And as for the battery and alternator up front, with the car off measure 12.1 volts, and with the car on measure 13.4-13.6 volts, which i believe is good.
Yea thats all ok ..but the fact that ur getting 5 and 7 volts with 2 diff amps is fishy
My friend's dad has done a decent amount with electricity and he thinks i may have fried one of the voltage regulators in my car...Is that a possibility?
I wouldnt think so esp if ur getting a solid constant 12v from the wire and ur new alt would rule out a voltage regulation problen i would think
---------- Post added at 09:57 PM ---------- Previous post was at 09:56 PM ----------
The voltage regulator is in the alt
Also, i failed to mention that i had my alternator rebuild because it was substantially cheaper and i am very good friends with the individual who rebuilt it. Would the alternator still work even if the voltage regulator was bad?
Yea it will still work but if he didnt replace the voltage regulator then it could be spiking or dipping ..you can have it load tested at autozone or another parts store
For awhile I was running 80ah yinlong on a stock 100-120a alt. Smart 5 sub amp and Audison APF8.9 bit stage amp. My voltage never dropped more...
4
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
454
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
brandonio21
brandonio21
Zanesville, OH
brandonio21
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
