Voltage drops? Help!
  • 5
I have a jl 1000/1 (v1) with 4 gauge wire and just stock alternator and battery and everything. When I hook up the amp to a sub with gain on about half (either my w7 or re audio sxx) it will play for a little bit but when I turn the volume up on my deck the amp light flickers than powers off but then will turn back on. I have never had a problem like this before so I need advice! I have never had a system with this high amount of watts tho.I went to a auto part store to test my battery and they said the battery is good and is getting a good charge. So my battery and alternator are okay. I think maybe my alternator just can't keep up with this high powered system. Any suggestions?? Would doing the big 3 help? Hooking up my capacitor help? Please give me advice!
Do your lights dim? Have you measured voltage anywhere? You're going to want to measure voltage both at the amp and at the front battery playing music about 3/4 of the max volume where it shuts off. Big 3 will almost always help.
What I'm getting at is that your electrical system probably cannot keep up with the draw demands of the amp, but it also might be a poor connection either on your power or ground wire, which those tests I mentioned above will show.
definitely get the big 3 done. Audio Technix is having a crazy sale go buy one of their 0 gauge big 3 kits that they have on sale right now. That will definitely help with charging
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
454
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Tshaffe
Tshaffe
robert420
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
