Voltage limiter for amps?
  • 4
Jerkyson
So I got a question. Ever since I got a high output alternator there are certain songs that manage to throw my amps into protection. I’ve been scratching my head trying to figure out what it is ever since I got it, checking connections and everything I could think of and I finally figured it out. When the amps draw a significant amount of power there is a voltage regulator delay that causes the voltage to drop and come back which I know is normal. Now, that isn’t causing the amps to shut off but what I finally figured out is that the voltage regulator also has that same delay in the opposite direction causing the voltage to spike for a fraction of a second and come back to running voltage when there’s no more current draw from the amps causing the amps to go into over-voltage protection. My amps really don’t like being above 15-16 volts or so and the alt is spiking to around 16.5-17 volts and coming back down to running voltage. This usually is an issue with songs with a lot of kicks making the voltage bounce all over the place. I’m curious if they make a device that will keep the voltage from going past 15 volts or so to my amps? Or maybe another solution? Other than that the alt is running like a champ! Thanks in advance for your guy’s advice!
It’s a 300amp Singer alt and just a stock Everlast battery
Car is an 03 Honda Civic 1.7L so there’s not much electrical load on the alt to begin with besides the amps
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
434
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Jerkyson
Jerkyson
San Antonio, TX
Spazz131
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
