Volume and station change steering wheel buttons with no ASCW-1?
  • 1
carwhisperer
CarAudio.com Newbie
I plan to put an aftermarket double din unit in my older Porsche. I would like to be able to control volume and station change from the steering wheel. My plan is to put 4 momentary buttons in the aftermarket steering wheel aluminum part. I have found a compatible clock spring with sufficient terminals.
On ebay I have found some head units that say: " Feature 2: Support steering wheel control+FM+MP5+Aux Input"
I'm wondering if I can use a head unit with this feature without the need for a steering wheel control box such as the ASCW-1. I'd rather keep it simple if I can.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
288
what ^ said. amp gain setting info, test tones are at the very bottom...
603
Factory. 2021 Chevy Silverado custom trailboss
9
866
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
carwhisperer
CarAudio.com Newbie
carwhisperer
Norther California
carwhisperer
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
