volume vs # of subs- need advice
vented
Ok. im trying to build a box properly, i have 2 Re se-x 12s and specs say they need/recommend 2cu ft. @33hz. My question is , is that per sub, like since i have 2 does that mean. i need a 4cu ft box? Or could i just account for sub displacement and they share 2cu ft? Thanks.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
129
what ^ said. amp gain setting info, test tones are at the very bottom...
455
Factory. 2021 Chevy Silverado custom trailboss
9
681
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
904
vented
vented
phenix city al
vented
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
