wall socketed lvl4xl video
does sundown have these subs for sale?
If I remember correctly, that sub was just a prototype named the 'monster'. I've read that a lot of the designs that went into that prototype are being put to use in the new Nightshade v.2
Also, that xl was making such a horrible noise. Did really well on the wall socket though.
Wow, lasted longer than I've seen any other sub plugged into the wall.
I do believe there is a video or two with a RD HeavyWeight with 220 going to it for 30 minutes straight, and they never could blow it. iirrrcccc
Let me see if I can find it, I was quite impressed by it
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
914
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
boom24
boom24
marshfield mass
dman4486
