walling off a car
You're better off waiting to get the 2nd zcon before you do your wall.
Easiest way to do it would build a box for your two Zcons in the back seat area and just build a baffle to go around it that contours to the shape of your car that seals it up.
well im going to just build two different boxes because its going to be awhile before i can get the second zcon. but how should i build the box? like ive seen like wooden rods like bracing the box ive seen a 2x4 board helping hold up the 75 pound zcon. whats the best way to do that?
well i mean what would be the difference in sound by bracing the box vs. not bracing the box?
You lose output by allowing the enclosure to flex. Another issue that can/will happen is that if the baffle itself flexes the sub can/will rip itself out of the enclosure entirely. You can also damage the enclosure by it cracking in various areas or seems coming apart.
alright so how can i stop all that from happening?
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
423
6
395
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
wetole
wetole
Pittsboro, NC
wetole
