Want to upgrade speakers
  • 3
Right now I have two 6 1/2 kicker cs speakers in the front, and two 5 1/4 kicker cs speakers in the back. Being powered off my headunit Kenwood Excelon KDC-X397 CD receiver at Crutchfield.com
Im going to sell these to my friend and some other things which might free up some money (think around $200) Id like to cut out a hole in my rear doors to fit 6 1/2 all around. Any suggestions? I figure I should look into getting an amp, speakers, and tweeters. What are some good brands to look for?
it won't make a lick of difference going from 5.25 to 6.5 in the rear doors and it is a lot of wasted effort with minimal gains (if any). your current limitations in sound are how your doors are treated (or lack of treatment) and available power (amplifier). properly seal your doors and seal the speakers to the door panel and you will be happier. then give them power. after that, upgrade if you want.
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
633
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
760
Biggiesmails72
Mount Pleasant, PA
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
