wasted ink's RE build
ive been slacking on the updates... between the cold weather and lack of funds, things have been slow.
i replaced the terminal block (the seller will know why //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif) and wired in some 8ga so the sub is set to go.
***Big thanks to Ray @ Audio Innovations for the terminal block***
sorry for the shitty pics..
Stripped set screw
Had to hold it up some how..
Using an allen wrench to loosen the bolt holding the block in
Terminal block free
Cutting the tinsel leads close to the old block, leaving as much of the old solder on as possible
Depending on what subwoofer it is, the leads will have to be bent upright to remove the block
New block/old block
New block bolted in
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
997
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
wasted ink
wasted incorporated
wasted ink
Southern NH
hehe
