Weird, at least for me.
  • 5
supereikenator
So I have an older Aluminum coned Rockford Fosgate T1 that I bought off of this website from a highly rated seller. I'm going to wire it in and running + to + and - to - for a final ohm load of 2 (it's a dual 4) issue is, it only works when I wire one coil and one either positive or negative, when I connect both it stops. Both coils are good, as I've tried each by itself and they work. This same configuration works on my Memphis C3, just not the Rockford, why would it be doing this? Solutions?
Alright, so I got it working before I had to go to work, for maybe 5 minutes, it sounded awesome, but now my amp goes into protect everytime I turn it above 12(out of 35) the wires are all snug. What is causing that? A short?
If both coils work on their own they should work parallel or series provided your amp will drive that load. If it does not your wiring to the subs is wrong or your load is too low for your amp.
It should be (+) to (+) and (-) to (-) my sub is a dual 4, same as the Memphis, my amp runs just fine on a 2 ohm load. I'm certainly confused.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
supereikenator
supereikenator
Strafford, MO
robert420
1aespinoza
    May 19, 2024
1aespinoza
    May 19, 2024
