Weird problem with my car audio unit
  • 3
KaiserD2
CarAudio.com Newbie
My car is a 2016 Ford Focus and the unit is the original one. It has worked fine with my phone and with my ipod classic which is the key issue. The radio and phone are still working fine but something bizarre has happened with the ipod--and the problem isn't the ipod.
To play the ipod you hit a media button on the unit. It gives you about five options, including usb1 and usb2. I always have the ipod on usb1. If it doesn't go on automatically, I just have to use the up and down buttons to reach the listing for usb1 and select it. Very simple.
Suddenly, however, the menu entries for usb1 and usb2 are dark and you can't select them. The cursor won't go there. The problem isn't the cable either--I tried a different one. I don't think its the USB port either because I tried usb2--no luck--and how could both of the ports fail at once? I tried a reset of the unit and that didn't help either.
Any ideas? Thanks in advance.
Well, this stumped everyone, apparently, but I eventually figured it out myself.
What was so confusing was that on its own the ipod was working just fine. However, just this morning, when I hooked it up to my desktop to load something, the desktop didn't recognize it. That is usually the cable but a second cable didn't help. Finally it occurred to me to reset the ipod. Presto! Both the desktop and then the car stereo recognized it. Apparently the software that announces it to a device had gotten corrupted. Now I can cancel my February Geek squad appointment at Best Buy!
DK
id put the subs in a ported box, and buy the proper amp to push them
29
3K
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
KaiserD2
CarAudio.com Newbie
KaiserD2
Watertown, MA
audiobaun
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
