Weird| Wired 2 4 ohm speakers in parallel and am getting a 4 ohm load!?!?
  • 2
Kold_Killa
My ski boat has 4 marine 6.5"s. The previous owner added 4 Pioneer Premier 6.5"s. I am wiring to 4 channel amp, so figured I would wire 2 speakers in parallel to present a 2 ohm load at the amp.
Issue: I wired 2 of the original marines in parallel, but the final load is showing 4 ohms!!?? I went back and pulled the "first" speakers to verify the connection was solid, and it was.. I also pulled the connectors to verify the speaker is a 4 ohm speaker, and it was.... This occured in both instances?!?!
I figured that perhaps I screwed something up, but proceeded to wire the Premiers and I am getting 2 ohm loads, with them wired identically as I do the marines. What gives?
I'd venture to say that I'm not making a great connection somewhere and it is only reading a load from one speaker, but for me to double check both sets and to present the same problem seems odd as I don't see why this is the case.
Anyone have any other ideas? Thank you
I don't trust existing boat stereo wiring, when I do boat systems, I replace all wiring, power, ground, speaker, etc. I usually replace the switch wiring as well. Boats are usually very poorly wired by whatever dealer or owner had them.
I have also introduced switching systems that let the owner power speakers from an amp when at cruising speed, or off the head unit when floating. It conserves battery power. I've also installed solar panels and chargers to supplement the boat alternator when outboards are used. The panels keep the batteries charged while sitting.
I should have mentioned that I made new runs of speaker wire with 14 gauge (previously to headunit and I made new runs to amp)... Again, why I find it odd //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I also installed a switch to my 2 battery setup, so that I can float and not worry about being able to start or not (a 1, 2, all, or off switch)... It's an inboard/outboard, so full size alternator.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
Kold_Killa
Kold_Killa
Little Rock, AR
Kold_Killa
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
