Prerunners are lifted for a purpose, mall crawlers are lifted for looks. There is a difference. A prerunner that doesn't fly over anything but pavement is a mall crawler.if your excluding prerunners then everything you said before that is meaningless. prerunners are just that, lifted 2wd trucks. the front it higher with prerunners for a reason, and anyone who has experience with them will know why. lifting a 2wd truck is usully just as expensive as lifting a 4x4. main diference is the elimination of CV wear and lower insurance.
and a wing on a Civic isnt useless because of the speed (or lack of), its useless because its front wheel driven. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
tires seem a bit small for the lift but otherwise the truck looks solid //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Lifting a 2wd is not just as expensive. You don't need to regear two differentials when you put bigger tires on a 2wd. You don't have to rework or get a new front driveshaft on a 2wd. You don't have to worry about front cv or axle damage on a 2wd which can save you money. Lift kits for 2wd's usually cost less than 4wd kits. Also you can just slam some spacers on the front of a 2wd and not have to worry about cv angles like you do on a 4wd. They are not the same for cost at all.
And for the civic wing a car can still lose stability in the rear even if its front wheel drive. A car can't only get light where its drive axles are...
