were should my sub sonic be at?
  • 4
play a 25 Hz not full tilt with the ssf at 35Hz slowly roll it down until the sub is being pushed near it mechanical limits. It might be 32 hz or all the way off impossible to tell without testing.
From my collection a Pyramid PB401a amplifier from 1986. Class AB amp claims 100 watts per channel. Bridgeable and has separate gain control for...
The CT's are nice, That Sundown is a a frik'n beast!
7
766
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
655
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
753
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
sq_joshua
sq_joshua
los angeles
dbjunior
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
