What amp + configuration is best for me?
  • 4
Twonders
CarAudio.com Newbie
I have a 2000 Monte Carlo and I'm kind of new to car audio. I would like to know how I should go about installing a subwoofer and replacing my factory amp. I'm unsure what amp I should get as well as how I should go about replacing the factory one. I'm also unsure if I would need a capacitor to help power everything or if that is just unnecessary. Some guidance would be very much appreciated!
What I'm Working With
I have an MTX Terminator 12" Subwoofer (200-400w RMS @2ohms)
An aftermarket Soundstorm ML41B head unit (40w)
6 factory speakers (Two 6.5"s, Two 6"x9"s, Two 0.75" Tweeters)
Factory Amplifier
What kind of install are you looking for? Are you ok with a box in your trunk? Do you want it to look factory? You have a lot of options for your install!
Factory Amplifier
Dump the 6"x9"'s and get a decent set of 6.5" components. JBLGTO609C $90
Yes you can if you have all the connectors in the rear of the stereo. There should be a bunch of rca connectors plugged in the back of it and if...
6
116
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
293
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
303
Twonders
CarAudio.com Newbie
Twonders
Pennsylvania
Bobbytwonames
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
