What Amp for Aq Hdc315
yeah if the AQ2200 is in your budget then it would be a good choice. the Hdc315 should be able to handle a little more than 1000wrms, but probly not quite 1300wrms, so keep your gains on the lower side. Another advantage to the AQ2200 over the AQ1200 is Headroom. it will allow you to upgrade your subwoofer situation later on down the road.
LMFAOATRMF'r //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
i see most people running 1500+ to there HDC3s
^^^^ what he said //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I've been known to throw 1301watts at my HDC's now and then //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
221
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
425
JHardee
Cadillac
JHardee
772 Florida
Bassdude22
