What amp to run on an Alpine type R SWR-12D4
topeteontop
i just bought the alpine SWR-12D4 rated to 1000 RMS , I'm having trouble deciding which amp to pair with this sub because alpine says it can take up to 1000 rms but a lot of people are saying this sub is overrated and is probably closer to the previous model with 600 rms, i don't want to overpower the sub if it is actually overrated and i dont want to over exhaust the amp if it actually is taking 1000 rms
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
176
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
379
topeteontop
topeteontop
corona,ca
DirtyDuzit
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
