what amp to run with 2 mtx 9500s?
slammer01
Hey guys I got 2 12 inch mtx 9500s dual 4 ohm. I am currently runnin a Hifonics Zues 2000D at 1 ohm. and that amp does not push those much at all. So I blew my money thinking it would power juss fine. Anybody know of a good amp to run with these? I was thinking of Planet Audio 2400.1 or A soundstream rub2500.1??????? What you guys think????????????????? Help??????????
http://www.caraudio.com/forums/amplifier-classifieds/554636-ab-vfl-450-1-hotness.html
this will punish your subs with an anal beating of epic depth and proportion!
What's your electrical look like?????????????????????????????????????????????????????????????????
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
138
369
slammer01
slammer01
New Haven, In
sleazebagger
    Jun 1, 2024
    May 31, 2024
